Marketing communications – going back to basics
Effective communication means getting the point across in the way you intend it to be interpreted, using your selected media platform to its best advantage.
Many great ideas get warped or shelved because they are not communicated clearly and persuasively to the right people, diminishing their effect and lowering morale in the process.
Think about the aims of your communications, are they to:
  • inform
  • instruct
  • persuade
  • negotiate
  • advise
  • discipline
  • challenge
  • motivate
  • involve
  • inquire
Are your messages:
  • clear
  • accurate
  • relevant
  • meaningful
  • timely
  • reliable
  • credible
Do you have any of the following communication barriers to contend with:
  • lack of message clarity
  • faulty presentation
  • mistaken meanings
  • incompatible views
  • incompatible personalities
  • deception
  • interference
  • inappropriate communication channels
  • Chinese whispers
  • genuine misunderstandings
As you can see, to ensure your marketing communications are effective you have to consider much more than initially meets the eye.  However, if you do take the time to work through this, then you are subliminally planning for contingencies as well as being thorough in your current activities.
If you need help to develop your company’s marketing communications, please get in touch.
Share
About Marie
I started Elite Edge 12 years ago and I am still as passionate about marketing today as I was then - probably more so because I consider myself very lucky to do a job that I love every day! My area of specialism is strategic planning but like most people these days, I wear many other hats too!
This entry was posted in Communications, Planning and tagged , , , , . Bookmark the permalink.
Leave a Reply
Your email address will not be published. Required fields are marked *
You may use these HTML tags and attributes: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
